Seat Heater Question - Install
Indiana
Website
www.intechrv.com
I've read the posts on installation of the aftermarket seat heaters and have a few questions. It's all wiring questions for the most part.
I am installing new leather and heaters...I am also installing a new stereo and subwoofer and two headrest monitors. I will more than likely want to add a few 12V power outlets or small 110V inverter also. The stereo will power off the standard source when I change the wiring adaptor...but the other items will need their own power.
I am thinking that I can run a large gauge wire from the battery (placing a main fuse close to the battery, not sure of the amps to use though) and then run the wires (negative and positive) into the interior of the truck.
Not sure where to come in at through the firewall...should I drill a new hole or find and existing one?
My thought would then be to run the wire to an area (under the center console somewhere) that I can have a single terminal to distribute the power to the items I need to power all on their own fuses that would be integrated in the panel...a panel I would buy at a marine store or something.
If I ran from that point to the seat heaters...would the 10 amp fuse in my junction box be enough, or do I need to maintain the 10 amp fuse that came with the seat heaters?
How do I make the seat heaters (and my subwoofer) dependent on the ignition being on, so I can't get out of the truck and accidently leave my seat heaters and subwoofer on only to return to a dead battery?
This is the part that confuses me the most, so detailed instructions would be helpful here.
Also, am I able to power the subwoofer and other components off the same fuse panel supplied by a single wiring source from my battery...or am I going to get feedback, noise or something like that into my electrical signals on any of these devices?
I believe my stereo has some sort of "power" supply, not actual power, but something that allows my sub and video monitors to power up when the radio is on, but I am not certain.
Any help in this would be greatly appreciated...I suck with electrical things, but if it's explained in extreme laymens terms I can handle it. I hate doing thing twice or wrong the first time, as you might imagine.
Thanks for your help!!
Rich
Just added seat heaters to the truck. This is what you need:
Painless Wiring Cirkit Bosses, part number 70207
Painless Wiring 70207 - Painless Performance Cirkit Boss Auxiliary Fuse Blocks
Fuse Block, 7-Circuit, Universal, Kit - New at 75.95 +shipping
I used the old cigarette lighter to energize the relay and ran a constant power source to the lighter. I have always disliked that the lighter was only on with the key on. This kit from Painless has half switched and the other are constant. The kit runs a breaker close to the battery. I stuck a 20AMP fuse in there to play with the seats but planned on going back to see if a 10 would be better. The firewall has a grommet on the passenger side I went through.
To answer the noise question, you need to verify that all sources have a good enough ground and use the same ground source to eliminate ground loops. Most aftermarket head units have an amp turn on lead, this will need to be wired into another relay to turn on all the equipment that should only be on when the radio is on.
That looks like a pretty nice item, I will give that some thought...surprised it cost as much as it does but it certainly will give me some options. I spoke with a member last night and got some great input on the factory wiring that exists for the seat heaters, I am probably going to try and tap into that for the seats.
