Seat cover for ivory/tan seats
San francisco
I want to replace the front seats covers, both are torn. I am open to replace both the bottom and the back covers
Do these covers come with the cushions/foam? as my vehicle has lost some of the foam under the cover. I need cover that comes with the cusion/foam or
can be purchased along with the cover
Also, do these new covers fit above the existing torn covers or I need to remove the existign one and put on the new ones
I will prefer removing the old one and put on the new ones (ideally if these are DIY).
I posted a year ago regarding the same problem but not sure how to locate that post
Read through this recent thread.
Post #10 is mine and gives you my experience with a good vendor.
If your foam is damaged, you can order new foam through Toyota / Lexus.
When removing your old leather, just cut the Hog Rings with a Good pair of Diagonal Cutting Pliers.
When doing replacement, IMO you do not need to use Metal Hog Rings.
Use Zip Ties instead.
Much easier to use / install / etc.
Good luck.
Tom
