Search is generating bad URLs
en route
The search function is intermittently generating bad URLs.
For example, this search: IH8MUD.com Forum - Search Results , searching for posts by semlin containing "fxxxed", generates this URL as its first result: https://forum.ih8mud.com/chit-chat-...ossible-35%-25-a-post2915988.html#post2915988
which generates a 400 "Bad Request" error
The problem is repeatable, i.e. that particular search always generates bad URLs. Furthermore all of the results for that particular search are bad. But not all searches are doing this, only a small minority.
I haven't investigated rigorously but so far I don't see a pattern. It's not just semlin, we recently saw a similar failure in TUT when searching for an old grrlscout89FJ62 post.
I'll wager that the "%" sign in the url is the problem....results from the SEO plugin....not sure that's a fixable issue however, but i'll look into it....
nice search term :p
Still happening. Pretty big PITA, makes search worthless for most users.
A useful search function I would think is more important that automatic parsing of URLs....I vote for dumping the SEO plugin if it's the culprit...
so, the bug only applies to threads with a % in them?
"believe" I have it fixed....but it may take a day to populate things....
the one strange thing that I have found with search is that if I do an advanced search in 'title only' for "ultimate", I get:
Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 71 bytes) in /home/forum/search.php on line 1123
(BTW I get the same result with 'thread' and '35%')
I'm searching for "60 series rear springs" in the 40 section
and I get this:
Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 71 bytes) in /home/forum/search.php on line 1033
they it's still a % issue....i'll try and find a solution, but if it's just that thread....well....lol
yep, discovered that issue this week as well...thus far, the solution's that should work aren't....
The original issue with the broken search link is because of the percent (%) sign. It is not being properly URL escaped and se the vbSEO rewrite rule breaks the link back to the correct path.
The percent sign's urlcode is %25, so simply adding the number 25 behind the offending % sign works. This seems to be (yet another) vbSEO bug.
The memory allocation on the search function... I dunno. Either vbSEO applied a modification that runs on large objects in memory (such as some sort of complicated url translation on all search results) or they are not freeing memory as they are done with stuff. 64mb of memory is way more than enough to perform a search :rolleyes:
