Search help on Vacuum
I thought a remember reading a few weeks back a post about how to use a vacuum gage on this forum. Post listed instructions someone typed out. I've searched and searched but can't find it. Anyone remember? I hooked my vacuum gage up and holds at 17 but the needle "ticks" about 1 in constantly. Romp on gas and goes to 0 then 25... let off gas and it spikes up to about 20 the returns to 17. The needle ticking, could this be unadjusted valves or burnt valves? (valves probably haven't been adjusted in many many years)
I posted some info in another thread before. Is it this???
Test with enguine warm - hook up vac gauge to direct vacuum from intake (brake booster works well). Choke should be fully open (off).
Normal Engine - 16-21 when idling. When throttle is suddenly opened, it should drop below 5 and then bounce up to 25 or so before settling back to normal 16-21 range.
Carb Out of Adj - needle fluctuates slowly over range of 4-5 units.
Spark Plug Gap Wrong - need fluctuates over smaller range (1-2 units on gauge).
Slow Timing - if engine compression is good and vacuum reading is low, timing may be slow. You can advance timing as needed to improve vacuum.
Defective Valve Action - if needle vibrates rapidly at idle - the intake valve guides are probably worn. If needle vibrates rapidly when engine is accelerated, there is probably one or more weak valve springs. An intermittent drop of 3-4 units indicates sticking valves whereas a regular drop indicates a burned or leaking valve.
Leaking Intake - a steady needle but extremely low reading indicates a probable air leak in the carb, intake manifold or gaskets.
Leaking Head Gasket - If the needle fluctuates regularly between a high and low reading, the cylinder head gasket has probably blown out between the two adjacent cylinders. Do compression test to check.
Leaking Piston Rings - Gauge behavior will be similar to normal readings except all readings will be down 3-5 units on gauge. Thus, idle readings will be about 13-17 or so. Do compression test to check.
