scraaaaping sound....
Denver, CO
hard to search on MUD for a sound.... :)
anyway, now that is is warm and sunny here and I have my windows and sunroof open, I am hearing a slightly scary sound coming from I think my back wheels, especially the DS. (or so it seems) It is a scraping sound, seems to pulse with the wheel rotation, and when I hit the brakes it stops but a really scratchy-rubbing sound starts that sounds like worn down brake pads rubbing, but I pulled all 4 wheels last night and all the pads look ok. I just peeked at the rear pads, but they seemed ok. Any ideas? I will try and take a look at the parking brake drum this weekend, could it be rubbing or sticking? The parking brake does seem to work. Thanks everyone!
T
Could there be something caught between the dust shield and the brake rotor?
That can sound pretty ugly...
Have you tried pulling on the e-brake as you drive? See if it makes any difference.
I hope that helps.
Alvaro
I hope that helps.
Alvaro
yeah, pulling on the ebrake stops the truck with no noticible change in the noise...I plan on trying this again outside of the truck with someone else driving, I have only listened from the driver's seat so far...
T
Check to see that the e brake is releasing when you release pressure on the brake. I had a broken spring on my DS rear and the shoes would stay slightly expanded when I released the e brake handle. Does that make sense? Have someone pull and release the brake handle while you watch the cable and the release lever at the drum. HTH.
THERE'S your problem...bad brake pads on the rear wheels. VERY luckily I decided I really needed to work on this problem today, so arranged to have Stacy pick up the boy. Good thing...on the way home the brake pedal seemed mushy...then when I pulled in the garage the wheel was smoking. Seems the inner pad got so thin it FELL OUT of the holder so the brake piston was rubbing on the rotor. It melted the boot around the piston so brake fluid was leaking on the hot rotor. Scary if I had been in the truck with Tyler. So anyway, I have the rear wheels off ready for new pads, which I am getting ready to call around and find and also a new caliper for that wheel. The rotor looks and feels ok. I have pics but the wrong laptop here to download, will post in the morning. Sigh....
wow, two in the same week! Read your first post and was going to suggest it was pads gone. My truck started making the exact same noise as I was coming back from off-roading with my 10 month old boy Saturday. Thought it might be sand or a rock in the shield, so I power washed it real good. Decided I had a little more money than time, so I took it to Midas. Drivers side pad had come completely out. They paid for the caliper cause they missed it on inspection, which I thought was rather nice of them. Two new rotors needed too. They showed me the rotor, which was worn almost to the cooling fins, and the caliper that had worn through 1/2" of the piston! Felt a little sick to my stomache that I'd driven with my boy in the car like that. I did rotors and 100 series pads on the front when I bought it cause the rotors were warped, so at least I knew the fronts would stop me. Kept planning on doing the rears, but always seemed to put it off.
Put off the the belts too, until yesterday when I went to spray some belt dressing on them to kill the squeek temporarily, and one of the matched pair was no longer there!
I'm putting a list together for crusier dan this week, so I can force myself to get caught up on maitance.
Glad you found the issue before you had any MORE damage done.
"It is a scraping sound, seems to pulse with the wheel rotation, and when I hit the brakes it stops"
When this similar sound happend to me it was a dry propeller shaft. Some lube in the zirks and knuckle cleared it up. I thought it was my brakes at first but those were fine. Just another idea if it isnt brakes.
