I am having a hard time with this pump I have from a scout II. To start, I identified the ps pump that is on my cruiser already. It has to be a chev saginaw, it looks almost identical to the scout II pump. Except it has a larger pulley, and the output fitting is different. All the stuff I've looked seems to imply that the pressure regulator you want to modify is behind this output fitting. The pump that is on my cruiser looks like it may be in there. It looks like it would be integrated into the fitting and will fall out when you remove the fitting. I haven't torn it down yet, but I would guess it's in there.
This scout pump has a brass coupler pressed into the output port. It seals against the flared tube that is part of the actual fitting. The fitting it uses is nothing special and is exactly like what's on the box itself. I am not sure on how to actually modify this scout pump, as I can see no regulator to modify. However I can see that behind this pressed in brass coupler, there is a smaller hole a ways in there. I guess that is what I'd want to drill out? I don't know how best to get at it. This pump is a fresh rebuild I'd like to use it.
Anyone modified this scout pump? Can you give me an idea of how to get the pressure regulator out? I could use the chev pump that is on the cruiser if I have to. I do want to figure this scout pump out, and make it push out the extra psi's.
thanks guys
thanks guys
