Scion headunit questions...
At the drag strip.
Hello,
I just recieved a scion headunit to install in my 94 and I had 2 quick questions to ask of the people who have already installed theirs.
First: I understand that the dash opening has to be enlarged a bit. What method was used to cut the plastic with good results? The plastic on my dash has gotten kinda brittle with age and I'm a little nervous about cutting into it. I don't want it to explode into many little pieces.
Second: Some of the posts mentioned that there were two sets of plugs in the dash... one for the security locked radio and one for the unlocked radio. I just want to make sure that I understand correctly. Which set of plugs should I use?
I'm hoping to get the radio installed this weekend and finally have a working CD player in my truck. Thanks in advance for your answers.
Joel
:beer:
I trimmed the dashboard with my Dremal, easy and very effective. Make sure you unplug the stock amp which is located in the back of the glove compartment. The plugs only fit one way so you won't be able to install the wrong one.
I also have a 94,
I used a dremel and them finished off with a couple of files.
I had to trim the radio bezel (left side) and the right side of the air control unit.
Just take your time, I cut a little to much on the top of the dash bezel.
Good luck
Thank you everyone who replied. :bounce:
Hello,
Joel
:beer:
I got also on ebay a Scion T1807 head unit for my son´s 2007 2 door Yaris, but I choose it specially because it still had the pigtails plugged. Why ? Because I was looking to use the Scion aux input to hook up his iPod.
So for you guys here is what you need to do if you would like to take advantage of this without spending a lot of money:
Besides the two standard connectors (A for power/front speakers and B for rear speakers), at the left side there is one with 20 pins for the Scion aux input / steering wheel control and one with 12 pins for the optional XM tuner.
The 2005/06 Scion got a aux input miniplug socket in the center console wired to the 20 pin head unit input but unless this socket is not connected to the head unit the radio will not aknowledge the aux input when you touch the aux button.
You can either purchase the wiring harness and miniplug socket at a Scion dealer which could be more than $ 80 or source the 20 pin pigtail from a recycler.
So if you get ahold the pigtail connector you will need two female RCA (one red and one black) plugs and a 2.2K resistor from your Radio Shack store.
Because Scion doesn´t use the same wire colors on the XA, XB or TC it will be safe that you plug and look the radio from the rear.
Uper row is for the audio and from right to left you will find at pin 19 a yellow wire which you will hook through the 2.2K resistor to the pin 16 ( blue or grey wire) which is the signal common ground for the left and right input but also you will solder to both RCA jacks ground tabs.
Pin 17 (black wire) will be the Left input which you will solder to the RCA center tab and Pin 15 (red or white wire) will be the Right input you will solder to the center tab.
The 2.2K ohm resistor will trick the receiver as if the stock Scion miniplug socket is hooked. Just touch the Radio aux button and it will be selected. This resistor info and value is not documented in any service manual. I did some tests until I found the right value. If you disassemble the Scion aux input adapter it should have this resistor inside.
Now you can hook on it either a RCA to RCA cable to your external XM or Sirius tuner or use a RCA to miniplug to hook your ipod.
Of course the ipod will sound better if you use dock to RCA adapter instead of hooking it through the earphone out.
Now regarding the 12 pin socket it´s used to hook the optional Toyota / Scion XM tuner but in the past was also used to hook the external CD changer. There are a couple of manufacturers who sell adapters to this 12 pin socket to provide another aux input and even ipod interfaces which can display song titles on the head unit display and control some ipod functions but cost between $150 and $250 !!!!
If you would like to add a nice touch to your Land Cruiser, the lower row of the 20 pin connector has 3 wires which go to the steering wheel controls on the Scion, so if you install a small push button on the left side of the column housing and hook to it the 8 pin (orange wire) and 10 pin (Light Green) every time you touch the button you duplicate the radio mode allowing you to change the radio input from Radio to CD to Aux !!!!
Hope you enjoy and take advantage of this info !!!!!
Robmir,
How about some pics or a diagram.
I'm the type that needs pics to help visualize.
Thanks
