Scion autodim rear view mirror NIB in ND
San Antonio.
Scion rear view mirror for sale, $120 shipped.
This is the autodim mirror Scion offers with homelink and map lamp. I ordered one before knowing my wife also got me one. I'll add the toyota part number after adding some pictures. The mirror has been out of the wrap to be sized for the window button which is also included. All the wires, mounting hardware, and button kit are still in packaging. The Toyota instructions are included and explain how to program the 3 homelink buttons and the various colors of the map light. It says reference the TIS system for installtion instuctions but I tracked down the gentex instrcutions (they make the mirror). Only thing needed for install the mirror that you might not have is a T20 torx bit to tighten down the screw.
I'll add the following info to my ad as well as a previuos Mud entry. Wiring scion mirror: Three wires need to be hooked up. The one with the white stripe is for the ignition +. For 80 series folks that means the sunroof power. There are also two black wires, one is constant power +(map light in the 80) and one is ground. The ground is the middle one.
Thanks
Forgot the part # PT374-21050. List price $280. Cdan can get them for about $200.
This would work in any cruiser not just 80's. But if you aren't driving any 80 you will have to figure out the wiring yourself. For 80 drivers I should have this figured out and pictured on a thread in the 80 section by tomorrow.
How would the mirror mount work with a 62? Could I use the existing mount location or would I have to glue to the window?
Thanks,
I am not familiar with how the mirror mounts on a 62. Is there a tab on the glass? If there is I think there are adapter to make that work. If it is ceiling mount like an 80 than no. You have to add the button mount to the glass.
I'll send you a p.m. for more info.
Price lowered.
No this is the Scion version of the Gentex mirror. Features:
Auto dim (you can turn it on or off)
3 channel homelink (replaces garage door and gate remotes)
3 color map light (I prefer the white but guys like Treeroot would the like blue)
Price lowered, last shot before it goes to Fleabay.
Sold.
