school me on how to.........
up on the MTN.in California
clean throttle body and what stuff do you use for cleaning? Carbs cleaning fluid?
Use only sensor-safe throttle body cleaner - not carb cleaner as it can damage the sensors. 3M makes some.
To clean it good you need to remove it. From memory...
1. d-connect neg batt terminal.
2. remove air filter, unplug mass air flow, and remove air intake tube. (unplug the mass air flow by removing the small spring clip/wire that goes around the plug, do not unscrew the two screws)
3. remove vacuum hoses.
4. remove #1 and #2 coolant hoses (one on the front of the TB, on on back, no need to drain the coolant you'll only lose a little.)
5. disconnect accelerator cable, cruise control cable, and throttle cable. Before you disconnect them make sure to tape off the adjustment nuts on the passenger side of the bracket so that when you reconnect everything you are close to proper adjustment.
6. Remove the 4 bolts holding the TB to the intake
7. Clean the piss out of the TB but don't get carried away on the IAC and TPS. Don't forget to clean the 3 tiny port holes inside the TB, just under the thottle plate.
Also a good time to replace vacuum hoses, front bypass coolant hose. If you have an EGR CEL code it's a good time to test the EGR VSV which is easier to access with the TB off.
Most dealerships sell BG throttle clean which probably is just like most brake cleaners. I use it on the cruiser and my wife's mall mobile and it works great. About $8.00. I just pull the air intake tube and open it up, spray it in, clean with a hard bristle brush, then a rag and let it run a minute while open and spray the cleaner straight in. It will bog the engine but it seems to clean it out pretty well. MoJ definetly has the right way to do it also.
