School me in front shaft tech
Boonsboro, Maryland
Alright. Have ball and claw axles, I know they need to go down the road, and I will go disks eventually here. Diff and hub are coarse spline.
If I do a mini truck disk swap with mini truck birfields, can I use coarse spline inner axles to match up to the diff?
So I would have mini truck fine spline hubs, and birfield and wouldnt have to swap out the third just yet. Do that down the road.
Basically question is is the innards of a coarse spline birfield coarse too. or fine 27 spline like the rest.
The inner axles where they connect to the coarse birf are fine spline, but I'm not sure it they are the same spline count as other late model axle shafts. I would assume that they are. By the way, the running boards are on the way.
cool, I would assume 27 spline then. Would work out good, just need to get the inner shafts then. I have the rest of the stuff for the swap aside from the funky inner axle seal, the diffs are large bolt so fine spline diff swap down the road should be cake as well.
hate to say it, but you are SOL....
stock inner shafts are available in only one option...30 spline at the diff and 27-spline at the birf, coarse or fine birfields....the ball-claw shafts and the coarse side gears in the diff both vanished at the same time (iirc, 1968)
Additionally, and even more work, is the axle housing itself requires modification to allow use of the newer inner axles.
BY FAR the easiest and cheapest is swapping housings....
DOH, I know of inner seal mod to make them work, but is there something else as well I would need to do?
So the side gears went fine spline before the pinion went fine spline correct ?
That is not really too big of a deal either though, I could just get an aussie locker for the front then or swap out side gears.
While on the subject I doubt it would work, but can a mini truck spindle go on a cruiser knuckle? I assume no or people would be going spindle out swaps and not have to mess with steering arm mods.
Weighing my options, Like I said, I have spare longs, spare mini knuckles with brakes and all just sitting here. Would be nice to put it all to good use. But full front swap will be the way if it all becomes a pain in the ass. I am looking for easy on this one.
minitruck spindle is the same as 79+ disc cruiser stuff and I "think" the same as 76+ disc cruiser stuff The steering arm/knuckle is normally upgraded since you would end up with those parts from the disc conversion anyways plus it is slightly stronger AND there are many more histeer options out there, plus there were only 3 years of that knuckle make, so replacements are less common.
swap side gears and crosspin gears so they match.....but that is easy enuf to do.
Once the seal mod is done, I don't know of any other changes required....
side gears went fine in 1968 with the ditching of the ball-claw....pinion went fine in 1978. Gears were all 4.11 thru 1978 then 3.70 in 1979+
Thanks Woody, That is a wealth of info. That would be awesome if I can just keep the stock knuckle on there swap the inner and birf, and keep the steering stock, This is mainly going to be a mall cruiser, with some mild trails. Dosent have to be beef. Although you do say knuckles are the same on disks, so I guess a drum knuckle is different than a disk knuckle. Always something. :)
drum knuckle = zero provision for caliper mounting
76-78 disc knuckle = same small steering pattern as drum
79+ cruiser and mini are the same
Forgot about that little caliper hangup. :D Guess you need that huh.
One last thing and you can quit answeering to my very newbie ???? here. disc knuckles are the same all around, So I could just put the cruiser steering arms on the mini truck knuckle. and be good to go. or does it have to be 79+ arms on mini truck knuckles. EDIT: found info, ok I need all late model cruiser stuff anyway. myswell swap full housing.
I would know some of this, but getting this crusier running is first on the list, Axles come next. I dont even want to look at them yet until the interior and engine are done. Thanks alot .
bolt pattern on the steering arm and caps is different on 79 plus than it is on the 76-78. only cruiser arms you could put on a mini knuckle are 79 and up arms.
