Scangauge question:"No codes found-Not Ready
6005 ft. Smoky Mtns. Idaho
I changed out my plugs, cap, and rotor the other day, and touched nothing else.
When I started the engine, the CEL came on.
Checked the scangauge, and it read: "No codes found; Not Ready"
It has always read "Ready" before, and "Not Ready" indicates (according to the manual) that "not all on-board diagnostic tests have been completed".
I disconnected the EFI main relay for 30 min, plugged it back in and started the engine again; same readout..:frown:
Disconnected battery 30 min; started engine, same readout..:mad:
Drove the vehicle for 30 min, and still got the "Not Ready" readout..:bang:
Called the dealership service manager (he said to disconnect EFI relay), checked the FSM, and searched scangauge threads here first, before posting this thread.
Has anyone with a scangauge had this readout, and if so, what did you do to reset ECU so that it will read "Ready" (to pass emissions) ?
Otherwise, what "on-board diagnostic tests" need to be performed to satisfy the ECU and/or Scangauge II ?
Any help would be appreciated..
I got a fj60 with a v-8 and have the same issue... if you find out what the problem was please post... I post if and when I find out what's going on...
I am very interested in this also. Is there any other way to get a "Readiness Test not Complete" from the OBD other than by disconnecting the battery?
