Scangauge for transmission temperature here you go !
Answered my own question. My Scangauge is reading ISO on my 04 GX. If yours reads ISO (should be 03-04 rigs) then you can use the following code to get feedback from your transmission sensor.
TXD: 686AF101B4
RXF: 044105B40000
RXD: 2808
MTH: 00090005FFD8
I will test it out some more as I just got it going out in the driveway. Current trans temp was 167* sitting.
If you are running in CANSF (should be 05+ rigs) then you might give the following code a try.
TXD: 07E021D9
RXF: 032180000000
RXD: 2810
MTH: 00070064FE70
Enjoy !
I am not sure which code I am using but I have my Scangauge set up to display TFT on my 2005. Works great.
NOTE - you must have the latest firmware version for the gauge to work though. I had to send mine in for an update before the gauge would work.
Correct, I think they are on version 4.46. If you find the code you are running and its different then what I posted above please post up and we will add it to the list.
