sc install please help
Richmond ky
I installed my sc today. I have a problem, there is a check engine light on and the code says something about a coolant sensor. The major problem is the truck will not start correctly, it may have to do with this sensor( i don't know). When you try to start it , it acts like starting a carb. truck without a choke. Once the truck warms up it works fine. It takes forever to start and runs bad for a few.
It would be really, really helpful if you posted what the code was and what year your truck is.
If your code is a P0115/116 then you are having some issues (or related issues) with the ECT sensor on the DS side of the head underneath the intake manifold.....make sure it is not unplugged or damage to the wire....of course checking the ECU where it goes in would be another good place to check.
Good luck.
-o-
would this cause the hard to start problem or are they unrelated.
Explain "hard start"....
Is the starter engaging and turning over numerous time before it finally engages and starts the truck?
Or are you not getting anything from the starter?
Or are you at least getting some clicking from the starter?
Also, was the truck working fine before you attached the SC? What mileage, maintenance history? These things are needed for us to give you some idea of what problem areas might need to be addressed.
Also, did you install the SC or did you farm it out?
-o-
I farmed out the install(do to personal time restraints), the truck was running great when i took it it. It did have a check engine light on. It has 150k on it, i had the radiator checked and it was clean, install a new thermostat during install.
what i mean by hard to start is the motor turns over fine and it try's to fire. It sounds like a cold carburated truck without a choke. Once it starts it runs real bad for about 45 seconds. During this time if you give it gas it will die. After this it runs well. But it seem it idles high when you come to a stop sign.
DISCLAIMER: I've never installed an SC or worked on one with it installed, so take my advice with a grain of salt. ;)
It sounds like you are having fuel delivery issues...maybe...the P0115/116 is related to the ECT sensor and is related to the throttle body/fuel injection system, even though it is an Engine Coolant Temperature sensor--
Personally, with 150K on the truck and installing an SC, I would have done lots of other things "while I was in there" to make sure there were no issues....head work, hoses, sensors, injector work, cooling system work, etc.
That said, I'd start with what the FSM states as being the issue: ECT sensor/wiring and fuel delivery to the engine: fuel filter, injector electrical connections, ECT sensor connections, etc.
By the way, who installed your SC? Did Toyota do it or an indy?
-o-
Since the problem didn't exist before the SC install so reasonably likely (unless Murphy is screwing with you) that the problem is install related. Didn't the person/company that did the job test drive before providing the vehicle to you?
As Beno says - a lot of maintenance stuff should have been on the list prior to just slapping the s/c on there and certainly having a CEL free condition would have been on the list. What was the CEL before the install reporting?
You have us 2nd guessing what was/is wrong because we don't have much to go on here. There are a lot of steps in the install and lots of hoses that have to be connected to this & that. Lots of things could go wrong in the install. Have you at least checked that everything is plugged into the right places. No binding of cables, etc.
Who did the install? I would assume that would be the first place to take it back or was it a mate?
cheers,
george.
the guy who did the install was a friend, and a retire dealer mech. He is not running from the problem, i am just trying to help him narrow down the solution.
I know i should have done the install myself and will pull it into my shop in the morning and go over the install.
Just started the thread to see if it was something simple someone else had to avoid several hours of looking.
Thanks for all the help.
He stated that there was a check engine light on prior to the install. I would guess unless you have multiple codes that the code 115 was already there and probably isn't the "issue" even though it is an issue in of its self. Did you know what the CEL was there prior to the s/c install?
Hard starting and burping like you are looking at would make me want to check a couple of things.
One is to check you feeds to your throttle body ie make sure they are connected correctly et al.
Did you extend your wiring harness for the TPC and IAC connections or cut into the wiring harness to try and move them? I would check those.
Also as Beno pointed out to check the wiring and connetions around the intake manifold is good. I know of two major things that could be of issue there. One is when you simply connect the cable braket for the accelerator cable, and the other two are the water bypass connection.
Another take is did you take the distributor off when the hard line for the water bypass was taken out?
Just a few things I would check.
Quoted from above post
"I farmed out the install(do to personal time restraints), the truck was running great when i took it it. It did have a check engine light on. It has 150k on it, i had the radiator checked and it was clean, install a new thermostat during install.
what i mean by hard to start is the motor turns over fine and it try's to fire. It sounds like a cold carburated truck without a choke. Once it starts it runs real bad for about 45 seconds. During this time if you give it gas it will die. After this it runs well. But it seem it idles high when you come to a stop sign."
I found part of the problem, the trd manual says attach the pvc valve to the intake manifold. the installer attached the pvc valve to a nipple on the sc just down from the one the brake booster is attached to. I will move this line from the pvc valve to the intake, but it is unclear in the manual what goes on the nipple on the sc just behind the throttle body. Please look at pics, I will continue working on this.
It sounds to me like there was some trouble with the wire harness when it was stretched over to accomodate the new throttle body location. I would check the connectors and the wiring by the egt. Is it possible he changed the timing? Its been a while since I installed mine, but I dont recall having to touch the dist for the install of the sc.
Get your friend to help you out on this - in my mind he kinda owes ya a bit of extra time and perhaps he can give you some insight as to what happened.
Can you highlight the nipple your talking about that is in question? It looks as if the hose from the pcv valve travels off the screen in that second pic.
I second the inspection of the harness and any splices if you needed to extend it.
Also im not certain but others have had hard start issues to a dist installed 180* out of position i believe.
I installed my S/C and there were certainly a lot of hoses that could have been installed wrong. I re-checked that each line was installed correctly at least 7 times before moving to the next step. The instructions can be confusing if you aren't careful. I would go back through and make sure every line is attached exactly as it should be.
I'll also echo that you should check the wiring harness. I extended my harness "one wire at a time" to make sure there was no possiblity of making the wrong connections.
I would definitely not drive it until you find the problem.
The only code I threw after the S/C install was a MAF code upon initial startup which was probably due to having a slightly damp air filter. But I cleared the code and I have been code free for about 5-6K miles.
Have you looked at my install guide? www.george4wd.taskled.com/scharger.html
Check all the hoses. Not sure what the BIG yellow T is doing in the picture?
When I did my install a few years ago, there was only one part of the installation instructions (to do with a small yellow tee - see my writeup) that was a little 'foggy'. Christo provided clarification from his install (probably one of the first that were done).
Anyhow, given it was running fine (albeit the CEL), harness, hoses, vacuum lines, connectors etc are all things to check. I'd recommend going through each step of the installation instructions and checking off that each and every step looks correctly done.
cheers,
george.
thanks for all the help, i will recheck the wiring harness.
George i agree on the yellow T.
JfZ80- the pvc valve is connected to the nipple just up and to the right of the air cleaner top nut. it is the nipple just like the one the brake booster line is connected to, but it is on the side.
