samurai buggy
Status
Not open for further replies.
northumberland, PA
samurai buggy in PA, $5000
ok, its time to sell my bro's sami buggy, we want to build new rig for 09, need $$ for parts, so something's gotta go, rig is located in northumberland, pa 17857
i'll make a detailed list of parts and the cost of everything when i get home, but here's a list of whats been done -
engine - 1985 22re, 140k, new timing chain, gaskets, water pump, fuel filter, etc., all done in the spring, custom fabbed engine mounts, spare starter, and cyl head, has a headman header, cherry bomb muffler, runs great
trans is an L45 4spd from an 82 toyota minitruck, stock clutch as far as i know, new master and slave cylinders this spring
tcases - trail gear dual case adapter, 21 spline, 4.7 gears in rear case, about 5 trail rides and 1 comp on the 4.7's, they work perfect and run quiet
front range center mounting plate for tcase/custom made crossmember/skidplate
driveshafts - rear is a lengthened 85 DC front minitruck shaft, with an fj60 slip yoke(huge u-joint), front is a lengthened fj60 front driveshaft, also have spare shafts
axles - front - widened fj60 housing, plus ifs wheel bearing hub bodies, taco brake rotors, fj60 calipers, kong's highsteer arms, 5th stud and tied into the steering stop bolt, 1ton chevy tie rod and drag link, 4.88's and aussie locker, longfield 30 spline front shafts and birfs, chromo drive flanges with 6 dowel pins, cut and turned knuckles, marlin HD shaft seals, trail-gear knuckle gussets and rock rings, rebuilt in the spring, 65" wms-wms
rear - 94 fj80 full float axle, 4.88's, aussie locker, stock 30 spline shafts, ARP hub studs, new axle shaft seals and whl bearing seals, factory fj80 disc brakes(HUGE rotors), 1.5" wheel spacers, 66.5" wms-wms with spacers, without the spacers you can only run 16" or bigger wheels, the spacers make enough space to run 15" wheels
suspension - front - spring over, stock fj40 springs, shackle reversal, 12" travel shocks(pro-comp i think), works great
rear - minitruck rear springs, custom anti-wrap bar with johnny joint, 14" travel shocks, suck-down winch, u-boltless spring plates
chassis is still a samurai frame, about 140 ft of 1.5" .120 tube, camaro seats(not pretty, but comfortable, 4 point harnesses, sheetmetal is a bit smashed up, wheelbase is at 96"
steering - fj60 powersteering box, ott industries flat pitman arm, big cooler, psc hydro-assist ram and pump, synthetic fluid
$5000, or i can find a set of tires for it for more, i can deliver it too, current wheels and tires are not included, will be sold on roller tires, pictures show the sheetmetal when its still straight, it's got more character now
detailed parts list w/ prices (at least as much as i can remember) -
Trail-Creeper Dual Case Kit, 21-Spline - $299
Trail-Creeper 4.7 T-Case Gears, 21-Spline - $349
Aussie Locker XD-21230 Model 8.875” rg $269.99(X2) = $539.98
4" Diameter V Belt Toyota TC Pump [PSCPP-2409] - $48.99
TC series Extreme Duty PS Pump [PSCSP-1200X] - $174.99
1.5" Bore x 6" Stroke Cylinder Assist Steering Cylinder [PSCSC-2206] - $119.99
PSC Cylinder Assist Hardware Kit - $39.99
(HK-2020) 6' Steering Cylinder Hose Kit A - $63.00
30-Spline Longfield Front Axles - $645
Longfield 4340 Chromoly Drive Flanges - $170
PORC L/C 4.88 [TLC488] $159.99(X2) = $319.98
PORC Toyota L/C 90/Older Master Install [TLCA] $119.99(X2) = $239.98
(TRK-110) H-D Tie Rod / Drag Link Kit - $250.00
OTT industries Flat Pitman Over The Top™ Steering Arm Part# SA0103 - $125.00
Kong's High Steer Arms(used) - $125.00
Front Range Offroad Fabrication Crossmember Center Plate - $54.00
Front Range Offroad Fabrication ARP Hub Stud Upgrade(in rear ff axle hubs) - $69.00
Warn Works 1700 lb. Winch - $124.99
Hedman Hedders Chikara 39400 - $155.95
Optima Yellow Top D75/25 650CCA/810CA - $172.95
Creeper Knuckle Gussets Kit - $39
MC-12149, Heavy Duty Front Inner Axle Seal, $7.49(X2) = 14.98
MC-12222, Wheel Spacers, 1.50" Wide - $89
Rock-Ring Kit - $19
Knuckle Service Kit w/ Wheel Bearings - $165
Knuckle Stud, $1.87, MC12100(x8)= $14.96
1 Johnny joint($44.95)+ tube adapter($14.00)+jam nut($4.00)= $62.95
heavy duty detent ball shift rail springs and bolts - $12
marlin trans shifter sheet - $10
almost every nut bolt and washer in this rig is grade 8, probably $200 or more just in that
86 cavalier electric fan, napa part# BK 8552104 - $119.00
Energy poly bushings, in engine & tcase mounts, and shackle hangers - $30
parts replaced with napa parts -
front rotor Item#: NB 4886575 Price: $41.99(X2) = $83.98
front caliper SDC 24261208 $41.19(X2) = $82.38
rear rotor Item#: NB 4886362 Price: $56.49(X2) = $112.98
rear caliper SDC 24261398 $51.99(X2) = $103.98
exhaust manifold gasket ATM JC584 - $23.69
timing chain kit Item#: NTP94148S - $81.49
valve cover gasket ATM JN185 - $7.49
oil pan gasket FPG OS20102C - $8.29
rear main seal FPG BS403451 - $14.69
thermostat ATM 1542404 - $14.09
dist. cap MPE EP671SB - $7.99
dist. rotor MPE EP484SB - $2.99
clutch master cylinder UP 709 - $21.49
slave cylinder UP 1359 - $10.99
inner rear wheel seal NOS 24642 $11.29 (X2) = $22.58
outer rear wheel seal NOS 13911 $4.99 (X2) = $9.98
fresh napa gold oil filter, oil change, air filter, fresh antifreeze - $45
belts(and new spares) - $50
rad hoses - $30
gold fuel filter - $25
longer front wheel studs from napa - $25
new lug nuts from napa - $30
used parts that we used, prices are approximately what we paid or what you would pay at a junkyard -
22re, with wiring and ecm, trans, and 2 tcases - $800
87 fj60 brake master cylinder and booster - $50
fj40 front springs/new bushings - $60
93 minitruck rear springs - $50
shocks, rancho 14" rears, procomp 12" fronts - $100
axle widening sleeve for fj60 axle - $50
fj80 ff rear axle - $350
fj60 front axle - $250
4-point harnesses - $100
tracker gas tank, dented one in it, good extra one - $100
The tube for the cage was about 100 ft of 1.5" .120 dom, and about 40 ft of 1.5" .120 hrew, we paid $5.00/ft for the dom, and $2.25 for the hrew - $625 with tax included
total = $8,116.12, im sure there are other things im forgetting, and obviously none of these prices include the cost of shipping, or fuel costs to go pick stuff up, which would add up to quite a bit
Status
