sahara bar light question
miami, fl
hi everyone, do the lights for the sahara bar work off the same switch as the lights in the stock bumper?
yes they do, but they don't have to, you can wire them however you want.
They do if you wire them that way. I would advise you to use the stock fog wires to trigger the sahara bar fog harness' relays, with the fogs drawing power directly from the battery like it's designed to do. The factory fog wires are really tiny. I guess if the installer tries to take a "short cut" and wire the fogs directly to the OEM harness, the fogs won't be nearly as bright as if you use the ARB harness (plus the wires could get hot or fry the harness in the worst case scenario).
