Sagging Butt
Lubbock Tx
Need some info. I have a 2010 Taco and the rear end sags, the springs are flat. About to go in for the recall notice they look ok except flat. Since they are only 8 yrs old don't want to go back to oem springs and be in this again in 8 yrs so need after market, just want stock height. Does OME make stock height springs and if so do they last? Any other spring makers out there that are any good? Thanks ahead of time for any info.
You could give an add-a-leaf a try. They usually add around 1 - 1.5" of lift, so if you're already down an inch with the sagging, then the AAL might get you back to where you were.
Have the recall done, then worry about aftermarket in 8 years. I had the recall done this year and am happy with it. Can't beat free springs to replace the 8 year old ones that were on the truck!
