Safe lifting points using a two-post lift
Kentucky
I have access to a two-post lift but I want to make sure that I use safe lifting points underneath. The lift is rated for higher than the weight of my 98 Land Cruiser so it can do the job with ease.
I've used the Search but I get hundreds of suspension lift posts so if I ever need information about lifting my Land Cruiser 1-4 inches I have all the info I need
The way I put mine on the lift - which are always Rotary two post lifts is put my tire just over the locator 'pad' mounted to the floor then get the arms to the best spot possible on the frame.
Remember if you don't use the lifts a lot you can always lift the tires off the ground and shake the rig a bit to get a feel of how well it is balanced on there.
