Spent yesterday afternoon drilling a couple of busted bolts from the rear sway bar link brackets. Was able to get the rear bracket bolts out without busting any but it tested my patience. It has made me wonder, on the swaybar brackets and bolts into the frame, why does Toyota have a half inch of threads sticking out the other side of the nut? Is this really necessary? Seems like this is just a recipe for busted bolts, the rust/corrosion builds up on the exposed threads and can cause the bolt to break even after you have started it turning. I think I’m going to replace all those long bolts with shorter ones. Same with the rear shock bolts.
I was pleasantly impressed with the quality of my O’Reilly Auto Parts left hand drill bits, they are nice and sharp and cut well without chattering.
I have learned, my underside is not really badly rusted or corroded, but I will never again approach the underside of my LC without a ballpeen hammer, a can of Kroil,and a torch!
