Rust removal
Little Rock, Arkansas
Next month I am getting my frame sandblasted and powdercoated and my tub sprayed with a liner on the underside and inside. My question is what have people done to remove light surface rust from there 40's? Take in mind that I am also interested in removing or stopping the rust on the back side of the body panels as well. Sould I bite the bulit and get the parts blasted while there off, or take them up to the fire station and work on them there in my downtime?
Thanks,
Jake
A lot of larger volume powdercoaters use a dip process to remove rust rather than sandblast, and one of the final stages of the dip process is a posphate dip, it makes a surface that is easily bonded to, and also gives a high grade surface protection, sort of like anodizing aluminum. The downside to chemical dip is that all the body sealer not only between bolt surfaces, but between spot weld surfaces is removed. The dip however gets everywhere liquid will flow, unlike sandblast that only gets the outside surfaces.
