Rust on Hatch
Al Gore
15 Year 10 Year
I am starting to get a couple small blisters on my upper hatch just below the rear window. I removed the interior trim panel with the intent of putting some rust inhibitor on the inside where the rust appears to be starting. I am unable to get to the area. Does anyone know of any tricks to fixing this problem without removing the rear window? BTW, I am not really the person everyone is thinking of
Al, that's indeed an inconvenient truth...:lol:
I have the same problem. Started out with one spot near center bottom and developing a new one about a foot to the right of that one. Must be one of the few flaws in the 80s design.
David Sword
Yeah, it's a design/workmanship flaw. From what I have come to understand, it has to do with getting complete adhesion between the rear window and gasket, also the gasket and the body.
I'm about to mitigate this issue on mine as the rust spots are now rust holes. I'm getting it all done for just under $1400, that's painted, assembled, and installed. Pretty good since the liftgate shell alone lists for $1018!:eek:
There are a few used ones around in junkyards, but I found a heck of a deal that made the new one only a few hundred more than used/repaint.
If you plan to replace w/ new, make friends with your local Toyota parts man/woman. This is not a stock part so they should be willing to cut a deal if you kiss enough booty!
I looked into getting it "repaired" at a local body shop, and nobody was able to convince me that they'd be able to fix it to my satisfaction. I soon found that nobody cares more about my 80 than me.
Good Luck!
AJ
I had the same problem, and I was lucky, there was a local junk yard that sold me the top and bottom for $600, and it was the same color.
