Rust on cylinder wall !
San Francisco
Currently doing an HG replacement. Left a damp towel over the open pistons last night :doh:
In the morning I see rust on the cylinder walls ! :frown:
What is the best way to clean this up ? can I use a 300 grit wet sand to lightly get the rust off ? brake cleaner does not seem to get the rust off.
thanks,
--don
thanks,
--don
If it's just overnight surface rust, wouldn't worry too much about it. Remove it with scotch bright and a little light oil (WD40 type).
thanks Kevin, Is light wet sanding ok as well ? ... and I assume no honing is necessary ?
I would not touch it at all. One or two minutes running after the Hg job is complete will take care of this. Also, there is a greater than zero chance of doing harm to the cylinder walls. Reminds me of a line from the movie: Entrapment. "don't use a cannon to kill a mosquito"
D
First wipe, spray some oil on it, WD40, whatever, all of the exposed metal surfaces to prevent rust. As DTAYLOR said it will be gone in short order when the motor runs. That said I would prefer to remove whats loose, not have it in the ring lands. I wouldn't sand on it, just wipe what you can off with a rag and/or scotchbrite with some oil and leave a film of oil to protect it.
Unfortunately I've already lightly sanded the walls using wet 400 grit paper.
I realize now I should not have... I don't think I sanded hard enough to remove any cross-hatching however.... but if I had... guess I will know sooner or later.
Guess I will hope for the best. I feel pretty sick about it.... am I screwed?
400 grit sandpaper shouldn't have hurt anything. You are dealing with steel, not a cornea :flipoff2:
If it were mine I wouldn't worry about anything other than getting it back together.
Agreed, clean it and put it together.:D
I appreciate the encouragement !
Should be buttoned up and running again this week-end.... I'll let you know..:-)
--don
For what it's worth, I know an old man here who is a legendary shade tree mechanic. He actually like to gets get light surface rust on cylinders when no honing is done to help the rings seat when the engine is fired up. I don't the science behind this, but after he reassembles an engine, it never smokes.
