rust found
Oroville, CA
Hi Guys,
I just found rust in 2 locations on the cruiser and wanted to pass it on. I removed the passenger inside rear plastic panel to access the fender flare nuts.
spot 1: There is a plug in the bottom most portion below the marker light. On one side of the cruiser this plug was gone and moisture was getting in causing rust.
spot 2: The bottom rail of the slider window had some visible rust creeping out below the weatherstripping (inside) and peeling it up revealed rust all along the rail. In this spot it looks like two pieces of metal are joined.
Spot 1 should be easiest enough to deal with, but spot 2 is gona be a bit of a job. Not sure what caused the moisture buildup, perhaps there are some clogged drains? Maybe someone could direct me to a thread on rear slider window rust
happy cruisin
