I have two main questions.
First, I have a CEL that is from a O2 sensor, and it is code 28. I am pretty sure that it is the one on the down pipe closest to the transmission. I am planning on getting a high flow catalytic and and going with a 2.5 to 3 inch exhaust system. My question is, can I make the O2 system into a single sensor system? Is it possible to bypass my faulty sensor and only use the good one?
Next question, I was dinking around under my LC and found a discouraging amount of rust on the rear axle. I think I might drop the axle eventually, and coat it all with POR15 or rust bullet. My parking brake was locked in the engaged position on the passenger side, and I had to tear it all apart and lubricate it like no other to get it working properly. Most of my hard brake lines are in need of replacement, and that I think will be my next weekend project, but my LSPV has quite a bit of rust on it to where it looks as if it needs replaced. What is the part number for the LSPV, and what are the usual prices for the part new or used?
