Just for flushing that is.
I did a flush with “Thermocure” 4 hrs. one day and two hours the next. After opening the radiator and block drain, I alternatively put the garden hose to the radiator fill and then to a temporary fitting on a spare hole in the head. Although that seemed to flush it out pretty well, I was concerned that remnants of the Thermocure may still be lingering in the T-stat housing and water pump so I wanted to run the engine and circulate while filling and draining. But I’d have to get the engine up to temp for the T-stat to open which is difficult while a fresh supply of cold water is being added. So, I tapped and added a 3/8” pipe plug to a spare upper housing I had. The bypass hose slips right over it.
I guess I could have just taken the T-stat out, but I thought this would force max flow through the engine.
Maybe this isn’t a new idea, but it was new to me & thought I’d share. This could also be used for testing when suspecting a bad T-stat.
