I have an issue with my 94 cruiser. Started it up this morning to drive to work and it was running terribly (no issues at all when driving the previous day).
Let me describle "terribly" for you; when accelerating or under any kind of load at all there is a very obvious, pronounced shaking of the engine. It is almost like the firing sequence is out. This is most prominnent in the 1000-2000 rpm range. Above approximatley 2000 rpm it seems to run fairly smooth, and under 1000 i.e. idleing or coasting there is a slight shake, but nothing major.
Check engine light is on - pulled the code (#12) which is listed as:
1 - Knock control sensor signal
2 - RPM signal
Here is what I have checked so far:
visually checked all intake hozes for leaks
inspected the air fliter
plug wires on the cap and plug end for fit
knock control sensor for broken cable (are there 2 of these sensors??) I checked the one on the right side of the engine near the oil filter
I replaced the plugs, cap and rotor about 4 months ago, and they have about 3000 miles on them.
Everything I have checked seems to be in order.
I am fairly new to landcruisers, and I have just a basic knowledge of mechanics so any suggestion or tips would be most appreciated.
2 - RPM signal
