running boards
Squamish
hey guys i know i should be doing a search on this but ive just taken off my running boards and i cant get those little black sorta rubber peices off that sit in front of the rear fender flares and at the bottom of the rear pass door....
there seems to be a bolt holding them on but the bolts just keeps spinning
If you find a solution for this, let me know. Right now this issue is one I have on the back burner. :D
oh really what sort of things have you tried to get these things off
I believe they are plastic inserts, I just yanked them off, my running boards are not going back, I something is going in it will be sliders, again on the back burner project.:cheers:
On my '94 there's 2 bolts that hold that rubber piece on. Both have nuts accesible with door open. Depending on how much road crud you have built up (mine is considerable), you can see the front one by just cleanin out the crud. The back one is a little trickier. You just pry open the back of your door mounted section of the flair, clean out the crud and bingo, there's the other nut. HTH:cheers:
Just take off the flare, it's not difficult and you can be sure not to damage the rubber piece. I, personally, like the way the rubber piece looks with the running boards off. go figure
