running board removal question
Central Coast, CA
Website
www.coastal-aquariums.com
OK this is a pretty lazy and lame question. Yes I searched, no I didn't see an answer. I was trying to remove my running boards and have a quick question. For the middle set of bolts it was easy with a 13mm regular socket and a deep socket for the top bolt. But the front and rear brackets don't want to come off with those sockets. The deep socket is too deep, the short socket it too short. Is there such thing as a medium depth socket? Or an appropriate really short extension? the other bolts came right off with no lubricant at all. Thats the benefit of living away from the snow, no rust!
wow.....from the looks of it, it would seem that a wrench would not get enough rotation to switch the position of the wrench on the bolt. It is dark now so I will try again tomorrow afternoon.
thanks
ratcheting wrench
Like this:
Wrench....just the old fashioned kind worked for me on the LX - Can't remember now if I used the closed end or the open end...
You know you just have to get the bolt loose enough to the point you can spin it the rest of the way out with your fingers right? :)
I haven't done mine yet, but I was thinking air ratchet - no?
That is when they aren't rusted in and/or crossthreading on the way out.
IIRC, I didn't quite have enough clearance for mine.
Rust? What's that?? :D
I feel for those that have to deal with rust!
And definitely a no go with the air ratchet on the top rear bolt...Some of the others you should be able to get to.
Yeah, my rig spent some time up north early in its life. The rust on the boards themselves wasn't bad, but the hardware was a pain to deal with. Seems like it's cheaper grade stuff than was used on the rest of the truck. Luckily my rig is almost totally rust-free otherwise. I had stressed the importance of this to the dealer I purchased the truck from--so much so that he had a creeper and a flashlight waiting for me when I showed up to look at the truck. It passed. :cool:
FWIW, some tips for those looking to remove their running boards:
1. Apply PB Blaster liberally to all nuts and bolts for a few days in advance.
2. WEAR EYE PROTECTION.
3. If the bolts start coming out easy, then get hard to turn, take a break and hit em with more PB Blaster. I found that by alternating back and forth between 3 or 4 of the rear bolts, they cooled down just enough after a few turns each that they came right out with no problems.
4. At the front of the running board there's a nut/bolt combo where the plastic cap is bolted to the fender flare. The nuts were so rusted on both of these that I didn't think twice; held the nut with a wrench and snapped the bolt off with a ratchet. If you don't plan to reinstall the rusting boards, save yourself the hassle.. snap them suckers off. :D
