Running board lights
canada
My driver side rear light was out. I decided to replace with 194 LEDs all around. The passenger side went well, the drivers not so good.
On the rear the original bulb was corroded and stuck in place. Green corrosion, almost like gum actually or something you’d see at the battery terminal. I’m looking to replace the harness component. I tried to take the bulb out but it was glued in there and I basically destroyed the terminals, wiring looks good, but the harness is toast. Can anyone help if this is the right part ?https://www.lexuspartsdirect.ca/p/Le...138060010.html
