"Run on" issue TBI 350
Crawlorado.com
Website
www.crawlorado.com
ok ive searched and searched, and tried just about everything..
Body is a 76
Engine is an 88 tbi 350..
When i turn off the ignition it keeps running..
a couple of people told me to put a diode in line between the battery and the alternator.. Ive Tried every combo of diode's every whitch way and cant seem to get it to turn off when i turn off the ignition..
the alt has two wires (brown, Orange) going to the dash, at the alternator the orange wire goes to a post, then out and back into the alternator into a Plug shared with the Brown wire... From the alt One ~12Guage wire goesout a post style terminal, and up to the Battery,
My Temporary work around is a switch in line on the "switched" power to the computer..
So anyone.. What kind of Diode,, Whitch way should it go.. or is it not a diode issue..
Thanks for any help guys..
Undo the plug on the alternator. If is starts and stops normal, thats the problem. You need to install the diode into the ign feed wire to the alt (which alt you got?)
Yea if i unplug the alternator wire it works fine, (except the sytem wont charge)
My Alternator looks like this
but mine is wired differently.. The Post terminal has 3 wires, one to the battery, one to the dash, and one that goes out and back into that plug on the alt.. the brown wire goes from the cab to that plug..
sorry i cant explain it better.. thanks for the help..
So would it be the White wire that i diode, or the white one (colors relative to the photo)
also what kind of diode?? The only 12v i found at radio shack is a little Zender diode.. And what way do i need to install it, Cathode-anode, Witch way..
Seems almost normal. One to the battery is the charge output. The one that goes out and back is a sensing wire to pick up system voltage. Many of us just run it directly to the plug. Either way should be fine.
Not sure what the 3rd one is. You might try tracing it to see where it goes and get back to us. You could also try disconnecting it, not sure what that would prove, though.
isotel said:
So would it be the White wire that i diode, or the brown one (colors relative to the photo)
Don't see a brown wire in that photo. :) But the diode goes in the white one. I think the anode goes closer to the alternator, but don't quote me.
isotel said:
also what kind of diode?? The only 12v i found ad cheacker is a little Zender diode.. And what way do i need to install it, Cathode-anode, Witch way..
Don't know.
The wire that comes from the dash (the white one relative to that picture) gets the diode. Go to radio shack and get one. You want power to flow from the dash to the alt (and be stopped from going to the dash from the alt)
The diode will have a band painted on one end, This is the end that points to the alternator.
Well said. That will cure it.
sweet, thats the only wire i havent tried yet.. And it is My Brown one( sorry getting confused with that photo) i will see if it works tomarow.. Thanks guys
Worked like a charm.. 12v zender diode from Radio shack, Cathode( or band) tword the alternator..
i put in an inline fuse holder in and pushed the diode into the slots for a clean install and eazy to replace if needed...
Thanks YODA..
