Ruined PS Pump????
Western Carolina
Ok, so when I put my engine back in I was inattentive to the fact that Toyota does not use PS fluid in the PS pump, and I filled it to the brim. I noticed that the PS was whining, and there is a ticking sound that appears to be coming from the PS pump. I guess I am asking if anyone has heard of this type noise from the PS pump or am I just going crazy trying to locate the engine tick. I put a mechanic's stethoscope to it and it is loudest right at the pump. I did drain the reservoir and put tranny fluid in it, but am afraid that I ruined the pump with the PS fluid while it was in there. Any ideas??
Sounds like the system needs to be properly bled. To bleed, do this: fill the system to proper capacity, jack up the front end, slowly turn wheel from lock to lock about 10 times (engine off). Watch the fluid level to make sure you don't suck in more air. Put the lid back on lightly and let it sit for an hour or so. Repeat this process like 3 times. Have a friend watch and once you get to the point where there are no air bubbles coming up in the reservoir and the fluid level remains constant, you can be pretty sure you've bled it properly. It should be OK to drop it and start the engine now. Turn the wheel lock to lock a couple times and listen for moaning/screeching.
-Phil
i dont think PS fluid can do that damage to the PS. try flushing it with atf then bleed it
If the pump is bad, I seriously doubt that choice of fluid had anything to do with it. There is nothing "trick" in them, just steel vanes on steel cylinder, so the biggest criteria in fluid choice is anti foam to avoid cavitation.
I think the PO put the pump on, it was an aftermarket job but there is an ungodly ticking sound coming from that area, very rhythmic but after ruling out EVERYTHING ELSE in the motor it is my last place to look. I have been chasing this noise for months, but I never thought of the PS pump. Is it possible/probbable that the vane or something in there is damaged enough to make a tick in the engine? Just curious.....
It's possibly a vane problem, but IMHO not very likely. My first guess would be the bearing going bad, it's a common inexpensive bearing. The pump is pretty simple to work on.
I might have experienced this exact issue, too. I had my freind who is a certified master mechanic for Toyota (day job) do a radiator replacement on my 94 80 and in the process, the power steering pump was removed because it was leaking. After rebuild and upon reinstallation, we had a very pronounced ticking/knocking at idle that we could not hear with engine revs because (we think) the engine noise drowned it out. So, we installed a brand new pump after three gear/piump remove/reinstall gyrations. And it was still there (with the original gear being used), which left only the gear. After installing the new $100 gear, it went away. Before you buy another pump, remove the unit, use a mirror and look at the condition of the drive gear in the housing on the front of the motor, and of course check the pump gear for any imperfections. We could not find any but the new gear solved the issue. Hope that is worth something to you. Regards, Kirk
Kirk, how do you get the drive gear out? Is it not on the back side of the block, inside the block? I know the pump vane gear is on the actual pump, but I cannot visualize removing that drive gear in the block. Good info though.....Thanks...
If this is a series FZJ80 we are talking about, on the front of the block is where the drive gear is. It is either a gear on the crank or driven within the group of gears that turn the camshaft, etc all being driven by the crank gear - I have't had that cover off so I don't know the exact configuration of what is under that cover. With the drive gear inside that front cover, you can look into the mounting hole for the pump via a mirror as long as you have someone to turn over the engine by hand to rotate the gear for observation. Make sure there is no damage to the drive gear before mating it to a new driven gear (on the pump itself) if that is the path you choose like we did. For whatever reason, we found no damage to either the drive gear or the driven gear, but once we replaced the driven gear (installed it just lilke we had the original gear three times prior) the noise was gone. Go figure.
