rubbing noise
Hi there ive got a 1992 landcruiser vx. A couple of months ago the splines on the end of my cvs and hub went so i lost front drive so replaced it with new cvs and hub. But after a while i ended up with a loud rubbing noise so took it all apart lots of times and then it dissapeared but 4wheeling this weekend it came back worse than ever and now the car shakes quite badly but once i stop its fine it generally does it after slow corners. The wheel bearings diff halfshaft cvs driveshaft all look fine well they did a couple of weeks ago when i last looked.I will pull the whole front axle apart this weekend but does anyone know what it could be?
Thanks
did you lube the brass bushings inside the spindles? if it is so bad that they are shaking they may need to be replaced.
