RTH: Upper bolt on Radiator
DocuDude
Took me 10 years to find this space
Los Angeles
I cannot figure out how to remove the two upper bolts on the radiator.
I can see it after removing front grill and headlights.
IS there a special socket for it, all i see is a long bolt with a nut on it.
Nothing I have seems to work.
Any help to get this damnnnnned thing off is appreciated.
I just replaced my radiator so this is fresh. They are 12mm bolts which you access from the front after you remove the plastic grill. The grill is held on by 5 Phillips head sheet metal screws. Both bolt heads are just behind the headlights so I needed a universal adapter to get the thing loose . The nut (in the engine compartment) is a special fitting which makes up part of the rubber mount which retains the radiator. It can turn but a needle nose plier can keep it from turning .I'm not near the car or I'd take some photos. Good luck .It's not really that hard once you find the bolt heads.
I figured it out
For future Folks, remove headlights & used deep socket 12mm
You can use your other hand to hold the bolt on the radiator side as you loosen it with socket wrench from front.
