RTH - Timing and dizzy
Minnesota
Okay, so I think I'm in a world of hurt right now. I was following the "How to replace an O ring" instructions and everything was going fine until I looked at the FSM and saw that the dots on the camshaft drive and driven gears needed to be alligned in a straight line (valve cover is off). So I turned the crankshaft tring to find the dots and align correctly. Then I discovered that they aren't aligning and I made a big mistake! :bang:
I decided that I should set the crankshaft back to zero where is was when I started. I'm guessing I have these two options to choose from.
Option 1 has dots and marks that look like they align on the top and sides, but nothing matching in the middle like the FSM shows.
Option 2 is another rotaion to setting the crankshaft to 0 (360 degree rotation). I noticed with option 2, the mark on the top of the timing chain gear.
Is there any way of telling how this should be reset? What should I do?
Okay, figured it out. Didn't realize the marks are on the back side of the gears. It's photo #2. I really should not be allowed anywhere near engines, but I just can't help myself!
