I hope I didn't really screw up my gauges. I've got the gauge cluster out to replace the famous 'D' light and in the process I dropped one of the screws into the speedometer / odometer gauge. I removed the whole gauge from the housing (four screws on back) when I couldn't shake it out. I could see it lodged in by the odometer but still couldn't get it to drop out. So I unscrewed the two screws holding the gauge face onto the unit and pulled the face off - the needle slides off pretty easily (which cold turn out to be bad).
I got the screw and put the face back on and tightened the two screws. Then I put the gauge needle back on pointing at the zero mark and against the zero-stop-rest thing. All was done with the vehicle off. When I started up the engine with everything connected, the needle jumped up to around 40mph while I was parked at idle
bang
I opened up the gauge cluster again and with the engine running pulled the needle off and put it back on at the zero mark, but it still seems to be reading a bit off. I can't find one of those stationary police radar warning things that shows my speed or I'd just drive by and see if I'm correct or not, and I don't have a GPS unit I can put in the car to check the speed. Also, I'm concerned this method wouldn't be correct anyway.
I'm thinking there MUST be a way to do this though, b/c I see a ton of kits sold on-line and in car catalogs for replacement gauge faces, and these would all require pulling the needle off.
Any quick thoughts so I can close up my dash?
ON EDIT: For those wondering, I had the dash further apart than needed trying to clean crude off the plastic parts on the face - I know, my fault for screwing with this stuff - ugh.
