RTH shock absorber
Oregon
I'm installing a iron man 4x4 2" lift as we speak and need to know correct orientation of washers and foam cells, plastic shock absorber cover and dust boot. Does anyone know the order in which all parts fit on the front socks. I think I have the order correct on the bottom of the shock but the shock was shipped work a really large foam cell bushing on the piston side of things. Does this larger one get removed so I can have all 4 of the smaller bushings? Or does the large one stay where it came from factory and you would only use three instead of the provided 4. It's for 1995 TLC . I am going the factory set up on bottom of shock. It's the top portion that of the shock that is my issue. Thanks in advance.
Jd.
