RTH: Removing the alternator
Utah
So I'm in the middle of trying to take out the alternator. I've followed the FSM to a T: disconnected the battery, unhooked the connections, removed all the bolts in order, now I'm down to the alternator itself.
The problem is that it acts like the pivot bolt is still holding it on, but there is nothing...
Am I missing something?
Thanks in advance
-Lane
BTW: I searched, and yielded nothing. :flipoff2:
I used a 6" 1/2" socket extension with a rubber mallet and tapped it out of the mount where the pivot bolt goes through.
It's a tight fit on the mount. It's tough getting in. I used some moly to slide it in.
Good luck.
-o-
Good luck.
-o-
OF COURSE, an extension... :doh: Why didn't I think of that?
Thanks, man.
Well, I got it off...had to remove the smog pump to do so... Beno's trick came in handy again.
I took it down to the local Checker Auto, who I'm well acquainted with, and had them test it.
Result: FAIL. It only put out 11 volts max. Failed all three tests, actually...One of them tested the regulator, though I can't remember what the other two were. This was a BOSCH alt.
Another reason to go with OEM parts on vital and important components...
