RTH - Pre-collision and ABS codes
kcjaz
Olathe, KS
So while I was driving down from Ouray to Silverton, planning to just wander around until COTR starts Monday, my dash lights up and says check pre collision system. There was no check engine light so I just kept going till I got to Silverton and pulled the codes. This is what I got.:
I cleared the codes restarted the truck and all seems fine but now I’m spooked as my plan just to go out into the backcountry and camp for two days and I’m solo. When this happened, my four low and CDL lights were blinking. I suspect I would’ve been unable to shift into four low and if I had been in for low. I probably couldn’t shift out.
Anyone got any thoughts on these codes? I’m not sure what I can physically check besides reading them and clearing them.
Edit: codes came back pretty quick after I put it in gear and drove a short distance.
Your rear wheel bearings ok? Brake fluid level ok?
Brake fluid is right at the hot min line. I can add some, but it should be OK. I’m about to climb under maybe pull a wheel and check things out. I drove up to Little Molas Lake lake and snagged a potential campsite while screw with this.
Maybe I’ll just have to run down to Durango and go to a dealership
