I have a Slee adjustable rear pan hard rod but corrosion has it frozen at a length to great for an OME 2.5 lift. It’s currently set for a four + inch lift and is therefore pushing the rear axle too far to the passenger side.
When breaking the bolt and adjustment loose, it destroyed the threads and can no longer be adjusted with a wrench. It can however be welded into place so that the rod is still useable.
So, that being said, I really need the measurement of a factory rear pan hard rod or an adjustable rear pan hard rod that is set for a 2.5 lift.
The guy at the shop said he needs the measurement from the left edge of both bolt-holes on the rod. That will provide the correct measurement for the rod length. Can anyone help me out with a measurement?
