RTH- Lights out!
Utah
I just searched through about 20 pages, and nothing I found quite describes what is happening...or what's not happening.
Here I go.
Started up my truck, went to turn on the headlights, but nothing happened. No tail lights, no clicking relays, nothing. So I get out, check the fuses and relays; all check out fine and dandy.
Now I'm thinking, it might be a fusible link. I check the FSM to see which one controls the headlights: the 'MAIN' link. Everything else on that link works fine: EFI, dome lights, hazards, horn, etc.
Ok, rule out the fusible links.
Next up is the combination switch. I can use the blinkers, and pull the stalk back to flash the lights. But that's about it. Here's a strange quirk though... If I pull the stalk back just slightly and fiddle with the switch, the tail lights will flicker on. :confused:
Is this the sign of a bad combo switch?
Just got back in from testing the combo switch:
No continuity between terminals A2 and A11 with 'Tail' switch 'ON'. The 'Head' switch seems to work, so does the 'High' switch. Both Headlight and Taillight relays check out OK.
:confused:
Edit: Yay, 500 posts!! ;p
It's getting cold out now, I can't do anything else to the truck until tomorrow...
Anyone?
Any help would be greatly appreciated.
:cheers:
Long day, including a lot of just devoured BBQ. :D
First thoughts:
1) Spray some contact cleaner into the combi-switch. WD-40 might do in a pinch.
2) Check the headlight bulbs themselves; need to rule that out anyway...
More thoughtful response coming tomorrow. (Buuuuuurp)
Hang in there,
Curtis
First thoughts:
Hang in there,
Curtis
:lol: Good stuff...
Thanks for the suggestions. I checked the bulbs just barely, they're fine.
As for the contact cleaner/WD-40, where exactly do I spray? I haven't taken the switch apart or anything yet.
Awesome, thanks man. But it's late and I got school in the morning... I'll do it tomorrow.
Enjoy your BBQ! :flipoff2:
:cheers:
It's tomorrow by 11 minutes....
tappity tappity tap....
I finally got around to doing something. Sprayed contact cleaner into the switch; nothing yet.
As far as I can tell, the stalk itself works. I can flash the lights, use the turn signals, everything that has to do with moving the stalk itself, but it's the light control switch at the end of the stalk that doesn't work. I think it's fried...
What would it take fry the light control switch?
Hmm... I don't think it's getting anywhere. Is it possible to disassemble the light control switch itself?
I'm e-thumbing through my handy-dandy eFSM, but nowhere does it mention how to disassemble the switch, only how to take it off.
What's with the DRL in your sig line - aftermarket? I wouldn't chase tearing the switch apart before fully checking the headlamp circuit and what might keep the lights from activating. Got a trailer hitch with trailer wiring pigtail? Aftermarket security system that makes the lights flash (and not flash..)?
DougM
DougM
I rigged the lights so they would come on with the truck, so I can drive in the dark. I did this after they stopped working. So maybe not true DRL....
I have checked the headlight circuit, before I rigged it, the only thing I can find wrong is the switch itself. I know that the lights and running lamps work.
Got the tow package, too. I have an aftermarket remote entry system, but that has been installed for over a year, and I have not touched it since.
I appreciate the help... I'll go double-check everything to make sure.
I got nothin'. :frown:
Time for a new switch?
Curtis
That's what I was thinking... There is a Japanese wrecking yard in Lehi, about 15 miles north, I'm going to give them a call and see what they have.
Just got back in... The only lights my remote entry taps into are the running lights.
I got REAL bored today and decided to just take it all apart.
I managed to get the steering wheel off, it actually wasn't that hard. Just a good, firm tug was all it took.
The combination switch wasn't too bad, either. All I needed to do was remove the lower plastic underneath the steering wheel and un-clip the two plugs from the harness. Following the FSM, I removed the headlight switch, then blasted electrical contact cleaner into it.
So far: 1% luck. If the headlight switch is in the "On" position, the running lights will now come on if I flash the brights.
:mad::mad::mad:
I guess I'll get that junkyard switch.
UPDATE:
I got a new switch, it came while I was out of town. Installed it on Monday, got my other electrical issues out of the way....Lo and behold, the lights work perfectly! :D:D:D
Thanks to all that helped! :beer::beer:
