RTH hot rotor/hub
Leadville, Colorado
My hub and rotor are getting hot. A year ago I rebuilt the front end and haven't had any issues till this week or so. I put 15,000 miles on since the rebuild.
I think it is the caliper is dragging, but not completely stuck.
I took the wheel and caliper off and the rotor turns aok (with opposite jacked up). Doesn't seem to be any play in wheel bearing. The inside of the brake pistons look cruddy, but I can't obviously see the exterior surface till I pop them out.
I don't think it is the wheel bearing, because they have been fine till now. They are not loose, (jack up vehicle and try to move wheel). There doesn't seem to be any noise/binding when I took the caliper off and spun the hub/rotor.
The pads are not wearing through, the rotor is not glowing hot. Just hotter than I would like (a lot hotter) Can the rotor really transfer that much heat to the hub? I am going to service the bearings once my rebuilt caliper shows up..
Would I be able feel a bad wheel bearing? How can I really tell the if the caliper is sticking? The rotor seems to be the hottest part. The pads are not glazed over..
THANKS
are the pads wearing evenly? front to back and either side of the rotor? notice any extra brake dust on either side? might not be able to feel a bad wheel bearing, but you can feel a loose one. and when you mean hot...is it too hot touch? or can you hold your hand on it for a few seconds?
Pads look ok, no excessive dust. Too hot to touch the rotor, even after not using the brakes for 10 miles at 5 degrees ambient temps..
The hub is hot, but I can hold on to it for a while
I should add, I think it is the caliper sticking because why would the wheel bearing preload go bad after putting 15,000 miles on it??
x2 on sticking caliper.
When were the calipers last replaced/rebuilt?
I was amazed at the difference new (reman) calipers made. Rears on the :princess: truck, fronts on mine.
Then again, they did have about 150k on them, so maybe it shouldn't be such a surprise. :doh:
If yours isn't too bad you can simply rebuild them. If they are trashed, get remans. Either way Cdan has what you need.
