RTH e-brake adjust
Big Island Hawaii
I'm adjusting my parking brake, and can only get the front shoe to actuate. I searched the ebrake threads and looked in the fsm but cant figure it out. I know its something to do with the flat bar that has a spring around it, but can't figure out the adjustment,
Thanks
Thanks
This gave me some trouble when I adjusted my ebrake a few weeks back, but at least on my cruiser it would do the same thing (only one pad moves) until there was resistance against that pad. Meaning if you hold it in place with your hand(or it contacts the drum when reassembled) the other side then begins to move. I am under the impression thats normal operation, but maybe one of the more experienced folks can shed some light on this.
I thought that might be the case, did you get an adjustment you were happy with? I think I'm going to button it up for now and maybe go back in there next week while i do my calipers...more on my cracked rotor later
Getting ready to rebuild mine. Turn the rotor so the little black plug is at the bottom. Remove the plug. Add a couple lug nuts to hold the rotor in place. Take a skinny screwdriver to move the adjuster through the hole tighten it all the way down then back it off some till a light drag
thanks, I got that part. I had the whole thing apart to clean and micro adjust per Parking/Emergency Brake Adjustment - IH8MUD.com post#23
when I noticed that only the front shoe was moving.
