RTH- Crank Seal
Prescott AZ
I am replacing my crank seal while doing the oil pump gasket and believe I damaged it. Everything I read indicated that it is installed slightly recessed of the cover. When I had it flush with the cover it had it's original round shape. After recessing it slightly, the seal deformed as you can see below, at the 12 and 3 o'clock positions. Do I need to yank and replace this before I start to button things up, Pretty sure I already know the answer but worth asking. Thanks
Yeah, that looks butchered. How are you pressing the seal in? When I did mine it went in smooth and I tapped it in till fully seated. What are you using to push the seal in?
Should look like (this before I replaced it):
cheers,
george.
Everything was lubricated with oil and it slid in easily, Ordered a new one already, and will go flush on the next install, thanks all:bang:
