RTH--Center diff won't disengage
Kalifornia
93 FZJ with CDL switch and 7 pin. I've been trying to actuate my lockers for a couple of months now. Recently (5 days ago) I pulled the transfer case indicator switch to test resistance and actuate it by hand a few times. Yesterday I hit the cdl switch accidently while pulling my keys out at a store. When I got back in to leave the ABS light and Center Diff light were both on for the first time since I have had my vehicle. Noticed the CDL switch was on so I turned it off, drove off and about 20 feet later the ABS light and Center diff light go out. This morn I was messing around with the cdl switch again but got no indications on the dash it was doing anything. Drove about 50 feet and turned into my parking spot at work and heard the birfs clicking and then the ABS light and center diff light came on and the center is most certainly locked (with the switch off and the transfer in high range) and now I can't get the center diff to unlock. Any suggestions? This is RTH because I am in a asphalt parking lot and it doesn't sound good when I turn the wheel.
It will definitely chirp when you turn the wheel, but you probably won't damage the CDL. Drive it to a gravel lot somewhere and drive in some circles. You probably just have some drivetrain windup that has got the differential bound. You can release some of that stored energy in a low-traction environment.
Got it--it feels like it is in low range though. Still okay to drive it on the road like that?
Alright, I got it disengaged now. It reengaged on its own after I drove around a bit so I took it to a dirt parking lot. What could be causing it to engage on its own?
If it really is in low range you can tell pretty readily... for one thing your engine will go about 10,000 rpm on the freeway (well, for a short time anyway... :D )
Okay, figured as much. It was shifting normally but I was just getting chirping when I would turn. I think my CDL switch might have some issues. Issue solved for now.
You can peel the dash back and unplug the CDL for now... That would be a good idea.
Great minds think alike. I didn't pull the dash back--the wiring harness is long enough to pull the switch out and disconnect it which I did.
