RTH - Birf Removal
NSW, Australia
I have stripped down the long side of the front axle to replace the CV joint. I am down to a blank axle, with the swivel hub removed, and nothing left on the axle housing. I can not remove the CV and axle from the housing. It seems that the CV jambs in the bottom of the hemispere as I try to pull it out. There is still a bit of clearance at the top, so I guess that the axle is not coming out of the diff in the center, and causing the axle to come on an angle, but it seems to be straight.
Any ideas?
I'm not quite sure what you mean here, do you mean you've removed the steering knuckle? If the steering knuckle is in place, then the only thing that I recall as blocking its way is the ABS sensor.
Yes, I have removed the steering knuckle. This is an ozzie HZJ80 with no ABS. It seems that the CV itself is just too big to fit through the end of the axle housing. It jams on the bottom edge. Because there is a gap at the top edge, I suspect that it is not coming out straight, but can not image why.
I have some photos, that I will try to post in the morning.
Yep, the flat sides need to be oriented top and bottom IIRC.
