RTH - Antenna woes
So I tried to tackle the broken antenna today. Had the stuff for a while and finally am getting around to doing it. I've searched all over Mud and FSM and can't figure out this stupid thing. I've already taken out the motor, removed old serrated cable, re-greased and closed it up. All I need to know is how to get the old antenna off! I have a 1997. The nut holding the antenna in was very corroded and fell apart. I am guessing that the old antenna is frozen in the motor housing but don't know if there is some trick to getting it out. I had to cut the old antenna at the base to get the motor out. Here are pics.
Do I just have to pull harder on the metal remnant? Do I have to pull out the plastic piece? Kind of stuck here and feel like I am just missing something obvious.
Thanks.
Push the up button and the whole thing should pop out.
I tried pushing the up button but antenna didn't do anything. The serrated cable has already been removed so the antenna isn't connected to the cable anymore. If the motor could push it up, should I be able to just pull it out? I hope my lack of exercise hasn't resulted in me being weaker than the antenna motor :)
Yeah, I just noticed that your cable is broken. I'm not near my Cruser or I'd go pull mine. IIRC there is a sleeve at the bottom of the mast that locks everything together.
There does appear to be a sleeve, on the new antenna and I think I see it on the remaining piece of the old one but can't get it to budge. I am guessing it just sort of wedges itself in to lock everything in place? If so I feel like I should be able to pull it out but try as I might I just can't seem to get it to budge at all. I even took the motor apart again and tried pushing up from the bottom with the old piece of cable, wire, and whatnot but it just kind of gets stuck about 5 inches up.
Any other suggestions?
Someone has to have suggestions - I can't be the only one to have experienced this problem.
So I finally was able to get the old antenna out and replace with a new one. It only took me a year to finally get it done :) The problem was that part of the antenna was stuck inside the pipe of the antenna motor. I ended up essentially disassembling the antenna motor from the pipe so that I could have access to the back portion of the pipe and hammering out the stuck antenna.
After that I still had trouble. If you look in the last picture that has the new antenna there is a metal sleeve that is about 3 inches long. The old metal sleeve was fused/stuck in the plastic tube of the motor and didn't come out with the antenna when I pounded it out. I ended up using a drill and drilled it out from above.
Just so anyone doing this later knows, the black plastic lining of the pipe is not supposed to be removed and is part of the antenna motor pipe portion. Also when drilling out the old antenna piece make sure the pipe is disassemble from the motor or a bunch of metal pieces will fall into the antenna motor and likely cause problems down the road.
Once the old antenna mast was removed, the install went smoothly. Getting the motor mounted and re-assembled was a little bit of a pain, but after having done this multiple times, it gets easier :). Installation of the new antenna was as described in the FAQ by John Davies. Greased the cable, extended the antenna, had my wife hit the up button until the motor stopped, placed the plastic cable with cogs facing rear of the truck, had my wife hit the down button and fed the cable into the motor.
Interestingly I still couldn't get the new antenna to come out again as described by everyone. Just to test it out with the new antenna, I had my wife hit the up button on the antenna with the antenna nut off and the cable and antenna did feed out of the motor, but the last bit of antenna cable was still being held by the motor and I couldn't get it to release. I tried pulling a little but it seemed pretty stuck in there and didn't want to pull too hard and break the cable of the new antenna and be back at square one. I guess we will find out when this antenna finally gives out.
Hope the information helps.
