RTH - 1HDT throttle shaft lever index on IP
TurboDennis
Toronto, ON
So I was replacing the throttle shaft o ring and had a small accident which caused the throttle lever on the injection pump to pop off before I had a chance to place the index match mark on it.
Im pretty sure that the factory line (match mark) on the throttle shaft was pointing just a bit counterclockwise relative to the throttle lever's body. (Like in my picture). Rotating it one tooth clockwise makes the mark perfectly parallel to the lever.
Could someone take a look at their IP to confirm? Thanks!
mine had a mark that matched the mark on the shaft. no be deal if your off a little bit. just fire it up it'll either run way to fast or just right.
