Routing wire through roll bars?
Spokane
I need to rout wire (CB,speaker) through my roll bars. Anyone ever do this or have some advice on how I should attempt it? I was thinking maybe drill holes and use thick wire to try and rout it.
cut your holes, use a shop vac on one end and vacume a pull string from the other end. Connect your string and pull your wire back. This at least works with electrical wiring in conduit.
I have done the oposite, used compresed air to blow some string thru, then pull wire ;)
