Routing cables through firewall on LC16
Raleigh, NC
I am working on new DRL module for my LC16 and need to route wires inside the cabin for a switch. Can someone provide some guidance what is the best way to route cables inside the cabin that easy reversible if needed. Per picture I am thinking about the location #2. Thoughts from anyone who routed cables?
I am working on new DRL module for my LC16 and need to route wires inside the cabin for a switch. Can someone provide some guidance what is the best way to route cables inside the cabin that easy reversible if needed. Per picture I am thinking about the location #2. Thoughts from anyone who routed cables?View attachment 1790011
Location 2. Cut the end of that rubber piece off off on both sides and feed through.
You definitely don't want to do #1. I ran 6 gauge duplex Anchor Marine wiring in waterproof sleeve (quick thick) through the firewall opening on the passenger side, and it wasn't hard at all to slip through a tiny slit in the boot. I recommend duplex or triple wire that way it's all in a bundle and you don't have to pull them individually. Here's the one I got and you can order it in a lot of different varieties:
https://smile.amazon.com/gp/product/B000NUX838/?tag=ihco-20
