Rough running '94 with a code 25 lean condition
890man
Thousand Oaks, Ca.
It started Thursday after a few days of rain. Thursday was sunny but humid for california. I got to work, 16 miles, no problem but I fire it up in the afternoon to come home and it runs rough like Im missing a cylinder. I pull the cap to check for moisture, looks good. Look over the engine, nothing disconnected. Jiggle the cable on the firewall, no change. BTW it has an aftermarket heat resistant cover on it already. I decide to drive it home. It ran poor the entire time.
Saturday, inspect intake hose for cracks and found none. I pulled some plug wires but couldn't get the rear two out and didn't want to break them. I know, I need to pull them. I took it for a drive (about a mile) and everything was fine. Good I have time to get a shop manual and figure it out.
Today, Drive a mile or so to get coffee and everything is fine. Leave parking lot and just as Im about to get on the freeway, it starts again. This time I get a CEL. It turned out to be code 25. Only now it quits at every stop.
I searched for info but I need help. There is talk of O2 sensors going bad. Is there a simple procedure for testing. BTW I cant search for "O2 sensor testing" because it drops the O2 WTF. Anyway, plug wires seems to be a problem also.
Why would the truck run ok until things heat up? Could this be an O2 thing. Does the computer go into a certain mode during warm up. I will continue to read and tear into the truck.
Try a tank of premium and a bottle of injector cleaner.
Well, no time to look at it today because of rain but the cap and rotor look good. The plug wires do have a date of 1995 however. Im guessing they are pretty old. The truck is a 12/94 with 132k. Could wires cause such a sudden problem like this? I will call Cdan to get some new parts coming my way. I may just get an O2 sensor as well so I know the history.
Thanks MoJ, I missed that one. It sounds just like mine. Was the injector plugged or just not working. You said you listened to it and it seemed to be working. BTW, what was the cost. I may have to take it in, I can't afford to have too much more downtime.
absolutely, the wires need to be changed, and i would change the cao and rotor while you are at it. mine was doing the same thing and i checked every thing as well. Ended up the #6 plug wire was grounding inside the plug well, replaced the wires and poof , problem gone, it would shutter at highway speeds and would stall at idel. good luck.​
Yea, I was pulling pretty hard on number 6 and it wouldn't come out. I didn't want to force it without a replacement in hand since the truck is still sorta drivable at this time. Ill get the stuff coming and keep my fingers crossed.
I am already thinking of pulling injectors and having them cleaned. How am I supposed to get to the injectors to test the Ohms of the coils and remove the injectors. It looks like a bunch of stuff needs to come off.
I don't have any details on exactly what was wrong with the injector. Listening to them with a steth is less than a perfect science. There's a lot of other noise picked up and I think it's possible to pick up the clicking from the other injectors. I don't remember the cost but I remember it sucked. IIRC the injector itself is a couple hundred bucks.
Sounds to me like you need a major tune up. From reading what I've read thus far, it seems that this has never been done, at least not as long as you've owned the truck. Start with plugs, wires, cap, rotor, fuel filter, adjust valves (if your year model needs that, check FSM, or someone on here with same year can probably tell you) as has been suggested already, a tank of premimum fuel and a can of injector cleaner, you might want to look at flush and fill the radiator as well since you probably have not done that since aquiring the vehicle. Basic maintenance will take you a long way and eliminate a bunch of problems that can lead you to unecessary and expensive repairs due to misdiagnosis. Always start with the basics, once you are sure that all of that is in working order, you can dig into more expensive and complicated fixes...
HTH :cheers:
Well, new plugs, wires, cap & rotor and still problems. I did get my shop manual Friday but I have a lot of reading to do before getting familiar with this thing. I finally made the decision to take it into a shop because I just don't have the time to figure this out on my own. Well, it appears to be #6 injector. The same problem as Moj. They say its getting a signal but not firing. I did ask them to check the harness while they are in there and re wrap with high temp wrap.
The truck has had all of the fluids changed including a coolant flush about 10 months ago. I am slowly, as funds permit, going through things. This board helps quite a bit. Very little free time does slow this down a bit. I don't seem to have as much patience as I used to. The fact that this is a DD doesn't help either. Anyway, I will keep all of you posted.
What'd the #6 plug look like when you pulled it?
#6 injector 4me2.....small world.
In fact, w8ing on the order from CDAN l8r this week and I should be back on the road. :steer:
FWIW...I also have a 12/94....I saw mention of using premium fuel on a reply post : my cruiser threw a CEL whenever I used it. I vary between 85 & 87octane and haven't had that prob since.
Hope it works out 4ya...........:cheers:
Funny thing, plug looked like the others. I drove it only 16 miles in this condition and waited two days to pull it. I could get pictures of the plugs but it will be a few days. Do you think there diagnosing the problem correctly? What would a plug look like if an injector wasn't firing for some time?
If it went long enough it'd be pretty distinct. I'd suspect it to be oil fouled, and pretty nasty.
A good guide:
Reading Spark Plugs Rich Spark Plug Photo
I'm sorry, but I'm going back to the engine wiring harness. That's a known failure spot that can cause behavior such as this. You mentioned it already had an aftermarket cover on it, yes? That would set off warning bells in my mind.
If you have new plugs, wires, and dizzy (cap and rotor) then that should eliminate those. The problem must lie elsewhere.
I did ask them to take a look at the harness in that location. I will stop by this afternoon to see if they found anything.
Just another thought. Im not sure if the injectors just go bad but if it was shooting a reduced amount of fuel and the plug is still firing the plug may look normal right. This would also explain the code 25 lean condition and a rough condition right. The code only came on once. I drove it to the shop 5 miles away today with no code. Thoughts?
In my case the plugs looked normal and there wasn't any difference between the #6 plug and the others.
Way too much cell phone texting for you, use the keyboard..its all there.
Its the ecu's two management modes: closed and open loop. When you first start the car and its warming its running through a pre-determined values programmed in the computer. Once up to running temp it goes into closed loop and starts to bring in the values giving by sensors to run the engine: o2's, air intake etc.
This is why it runs fine cold/warm-up but not at running temp.
Im sure there's more to it but this is what i know :grinpimp:
For any car with fuel issues thats uncertain I try a can of BG 44K with a tank, the stuff is expensive but its the only one worth a ....
No kidding, I had to read it twice:D Thanks for the input MoJ, I feel a bit better. Now if I can just get rid of the pain that having someone else work on my junk is creating:frown:
