Rough idle
Intake hose sounds like it makes sense but i cant find a leak on it. Found the hose on line but it was close to $200 including all 3 sections. Compression test was all good, but I checked my 2 week old plugs and two were perfect and four of them were black. still tryin
One big fat piece from CDAN is less than $100. Be careful to check in the ribbing where it accordion bends a little. Very easy to split one if it's got any age at all on it.
No response from CDAN. Any other sug for good price on intake tube?
Ask for Beno or any of the other parts guys there and mention that you are on Mud and you'll get the same price. Dan is either still out playing with his new car or still swamped with the recall stuff. He's a busy dude and slowing down in his old age. :eek: ...and I ought to know since he's only a couple months younger! :lol:
That's pretty funny Brent! :lol:
That said, I'm at job #2. One of the other old geezers at American will have to help the OP out.
Deebo6 - did you ever verify a leak in the intake tube? I saw they were suggesting you use WD40 but I have always used ether starter fluid. Let me know if you found an issue with the tube.
I am curious as to why two of your plugs looked good and the others did not? Anyone have any thoughts on that?
If you are in the area of a dealer, I would again suggest paying out the $65 for the analysis if you can afford it. Otherwise, I fear you will be replacing parts blindly in the absence of actually finding a failed part.
So there are no codes correct? No obvious vac. leaks? My 93 ran like stank and i whent to change the air filter an shazam freakin hose almost split in two. Replaced it with a universal flex air intake tube from orielys and runs awesome now.
When you replaced the IAC, did you clean the air passage through the throttle body that the IAC controls? This passage allows air to be diverted past the throttle plate when closed at idle. I just worked on two vehicles with this same problem, and those passages were 90% plugged. Cleaned them out, and this solved the problem both times.
I would recommend removal of the throttle body in order to get a good cleaning. Also inspect the intake plenum for gunk. I also cleaned this out when I had the throttle body off.
Very simple fix to what seemed a very complex problem.;)
I actually gave my rig to a friend who works at a dealership and waitin on a call sometime this week. No vacuum leak, good compression test, replaced coil and module. Cleaned every intake spot. Hes gonna run some kind of leak test on my valves. Aif filter is brand new and so is fuel filter. Discovered 6 new fuel injectors, this little problem must of been happening for a while. Even if its a valve problem Im gonna fix it, love the truck always wanted one! Thanks for all the input
